Date/Time: Sun, 22 Nov 2026 14:14:03 +0000
SIERRA ALERT TIME NOW OFF BY 4 HOURS
View Count: 236
| [2026-10-05 20:22:15] |
| User452635 - Posts: 60 |
Dear Mr. John Downloaded the latest Sierra version 2957. But still the Alert Time is Off by 4 hours. Can you please suggest how to correct this ASAP. I'll greatly appreciate your help in this matter. Message Log sent for your kind perusal. Thanks. Robin. |
| [2026-10-05 21:44:08] |
| John - SC Support - Posts: 48610 |
Your Global Time Zone is set to UTC. Is this the correct time zone that you want for your system? If not, then you need to change the time zone settings to what you want for your charts. Keep in mind there is a Global Time Zone and chart specific time zone settings. By default, the charts use the Global Time Zone, but you can change this per chart. Refer to the following: Time Zone Setting For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
