Date/Time: Fri, 20 Nov 2026 18:48:54 +0000
Snap to tool
View Count: 222
| [2026-10-05 10:04:52] |
| Rafalitto - Posts: 13 |
Hola, buenos días. Me preguntaba si existe alguna herramienta que sirva para hacer snap (igual que se imanta a velas o mechas) de un fibo nuevo, pero no con las velas sino que se imante hacia cualquiera de los niveles de un fibo creado anteriormente? Gracias |
| [2026-10-05 14:21:38] |
| John - SC Support - Posts: 48608 |
From Google Translate: Hello, good morning.
I was wondering if there is a tool that allows you to "snap" a new Fibonacci tool—similar to how it snaps to candles or wicks—so that it aligns with any of the levels of a previously created Fibonacci tool, rather than snapping to the candles themselves? Thanks. There is no support for "snapping" a drawing to another drawing. The only supported snapping options are to the parts of the bars (Open/High/Low/Close). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
