Date/Time: Sun, 22 Nov 2026 14:14:02 +0000
Accessing Sierra Charts X-Axis directly.
View Count: 297
[2026-10-04 19:14:56]
User92573 - Posts: 622
Dear Support,
Is it possible to access Sierra's time axis directly through ascil so that Sierra's code for crowding can be used.
I want to create a secondary offset axis that mirrors the time text on Sierra's axis.
I have created a separate time line with an offset and anti-crowding but I'd prefer to show only the ticks and time presented on Sierra's axis.
At the moment I can create my own timeline using tools but the time location and ticks do not mirror Sierra's placement which would be ideal.
Many thanks.
[2026-10-05 14:07:49]
There is no support to access the specific times that are displayed on the X-Axis.
[2026-10-06 10:58:40]
I think I was a little too hopeful and trying get off too lightly.
Okay, I can see there is a way to obtain pixel width and changes so I can achieve a pretty good outcome using this.
Many thanks.
