Date/Time: Fri, 20 Nov 2026 18:22:56 +0000
Third-party developer: answering questions on the Support Board
View Count: 415
| [2026-10-04 12:57:19] |
| User833459 - Posts: 11 |
Hello, I'm the developer of TradeRecall (https://traderecall.app), an automatic desktop trading journal that records fills from Sierra Chart on the same computer. Two questions: 1. Is it acceptable for me, as a third-party developer, to answer questions on the Support Board about TradeRecall when users ask about it, with a clear statement that I'm its developer? 2. Does Sierra Chart list third-party tools anywhere, or is the Study and System Programmers page the only such list? Thank you, Stjepan Mikulić |
| [2026-10-04 19:00:40] |
| Sierra_Chart Engineering - Posts: 25447 |
1. Yes this is just fine with us. 2. There is another area. It is the custom study store. We need to do a review of that, and make sure it is all working as intended and easily accessible and easily found. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-10-27 14:13:13] |
Hi, Different question this time. I wrote a small custom study that saves where every chart window is and puts them back when the monitor setup changes, for example from 5 screens to 3 and back. It's free. A few people here asked for exactly this: Unable to use/see complete Chartbook on Laptop versus Desktop Saving chart windows positions? https://www.sierrachart.com/SupportBoard.php?ThreadID=65893 Is it ok if I reply in those threads and tell them the study exists, with a link to where they can find it? I'd say clearly that I'm the author (TradeRecall). Or would you rather I send it to the custom study store first so you can check it? Thanks S. |
| [2026-10-27 17:00:30] |
| John - SC Support - Posts: 48608 |
We do not check/test third party studies. The Custom Study Store is just something we make available so customers can connect to developers. You are more than welcome to post in those threads and tell people about your study. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
