Date/Time: Thu, 19 Nov 2026 17:32:19 +0000
Nymex-CL Pricing
View Count: 278
| [2026-10-02 14:53:08] |
| User841161 - Posts: 357 |
I am currently using Top of the Book data. Why are the 3 Crude Oil Charts showing different pricing?
| [2026-10-02 15:57:08] |
I figured out, got messed up when I was trying to use a second computer, also there was a session time issue on my end. On the second computer used, I thought if I disconnected to data feed it would be ok to use 2nd computer? |
| [2026-10-02 19:53:14] |
| John - SC Support - Posts: 48593 |
How did you "disconnected to data feed" on the second computer?
| [2026-10-02 20:04:54] |
In main instance in File tab- hit Disconnect. But did leave the 2 instances open on 2nd computer. I don't know if something was something still connected disallowing main computer not to connect?
| [2026-10-02 20:31:11] |
File >> Disconnect should have taken care of it. Let us know if you have this occur again. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
