Date/Time: Mon, 09 Nov 2026 12:28:25 +0000
MNQ historical quote data and original receive timestamps
View Count: 282
| [2026-10-01 21:10:44] |
| User623672 - Posts: 1 |
Hello, Before purchasing a package, could you confirm whether Sierra can provide an export of approximately 800 distinct historical MNQ trading sessions with: - Raw trades and every best-bid/best-ask update between trades, including quoted sizes, not only quotes attached to trades. - Original capture-server receive timestamps in addition to exchange event timestamps, with their clock origin and actual precision documented. - Preserved event ordering, trade aggressor indicators, and trading-status/reset information. The standard SCID format does not appear to expose a separate original receive timestamp, and your documentation states a maximum 180-day retention for downloadable CME market depth. Is there another native/raw historical archive or export that provides the above fields over a longer period? If so, please specify the available MNQ dates, the export format/schema, and the minimum package and total cost for historical-only use. Would Base Package 3 at USD 26/month suffice? A small technical sample or format documentation would help confirm compatibility. If these fields are not archived, please confirm that explicitly. This is an information request only, not an order or service activation. Thank you. |
| [2026-10-01 21:19:37] |
| John - SC Support - Posts: 48459 |
You can not export the data out of Sierra Chart and use it for any purpose. This is a recent change due to changes from the exchanges, so anything you have seen/read previously no longer applies. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
