Date/Time: Mon, 09 Nov 2026 15:09:38 +0000
Mirco Yields
View Count: 200
| [2026-09-29 15:02:18] |
| User841161 - Posts: 357 |
Are there certain settings that need to be applied to chart the CME micro yields? They don't seem to be charting normally.
| [2026-09-29 15:47:26] |
| John - SC Support - Posts: 48464 |
This product is not traded at all. Refer to the following: https://www.cmegroup.com/markets/interest-rates/us-treasury/micro-30-year-yield.quotes.html We see 2 data points for the V contract, so this would imply that what you are seeing is a scaling issue. Make sure your scale is set to "Automatic" and then reset the scales. Refer to the following: Chart Scale and Scale Adjusting: Automatic (Scale Range) Chart Scale and Scale Adjusting: Resetting the Scale For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-09-29 16:24:15] |
ok, thanks. Yeah just using it to chart yields right now. The resetting corrected it.
