Date/Time: Thu, 12 Nov 2026 23:38:06 +0000
Quoteboard issue v2957 - Right-click context menu selection is applying to wrong symbol
View Count: 702
| [2026-09-28 17:05:42] |
| n8trading - Posts: 87 |
With the new quoteboard functionality in SC v2957, if I right-click a symbol in my quoteboard to roll the symbol forward or backward, it is applying to a different symbol (two symbols down from the one that I right-clicked on).
| [2026-09-28 18:46:01] |
| Sierra_Chart Engineering - Posts: 25418 |
Were those two symbols down already highlighted?
| [2026-09-28 18:52:55] |
No. I was/am very careful to single left-click the quote that I want to roll first (it highlights orange), then I right-click it and roll and the roll actually occurs on the symbol two symbols down from that one that I clicked/right-clicked on.
| [2026-09-29 21:22:13] |
We are going to be releasing version 2961, a pre-release, later in the evening. We want you to update to that version and see if you still have the issue. We have done some work on this functionality and we do not see it in the latest version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-10-01 01:15:11] |
The issue remains and seems to be the same in 2961.
| [2026-10-01 04:15:21] |
Maybe this issue relates to when using sorting of the rows. We will test this. Also do not use version 2961. There is a problem with that version related to Intraday data files. Install the previous version with Help >> Install Previous Version from the main menu. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-10-01 23:45:58] |
Are you using sorting on the symbol? One thing to be aware of is when you roll forward, the sorting can change. And make it look like you are rolling forward a different symbol. We cannot identify any problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-10-01 23:46:01] |
| [2026-10-02 13:14:10] |
No, not sorting. The issue only occurs when the quote board is attached to the main window, and it isn't consistently 2 symbols away, it looks like sometimes it is 3 symbols away. No issue when the quoteboard is detached. |
| [2026-10-02 19:24:51] |
That is very strange. It should definitely not matter whether the Quote Board is attached or detached. In our testing with this, the Quote Board is attached. At this point we do not know what the problem is. We probably need to get your Chartbook which contains the Quote Board and test this. Instructions to provide the Chartbook: Support Board Posting Information: Attaching a File (Optional) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-10-02 22:21:16
| [2026-10-22 17:36:23] |
Chartbook attached.
Private File |
| [2026-10-22 22:17:42] |
We have tried twice now to reproduce the problem but cannot with the Quote Board in the provided Chartbook.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-10-22 22:18:07
| [2026-10-23 12:19:30] |
More details: - Maximizing the Quote Board window inside the main window makes the problem go away. It only happens when the Quote Board is attached and not maximized. Detached works correctly. - The offset depends on where in the row I right-click: near the top edge -> 2 rows down, near the bottom edge -> 3 rows down. So it's a constant pixel offset (about 2.5 rows), not a row-index error. - Moving the un-maximized Quote Board around inside the main window does not change the offset. - It happens on both a 1080p and a 1440p monitor, all at 100% Windows scaling. Hiding a toolbar does not change it. - Left-click highlighting always selects the correct row. Only the action from the right-click menu goes to the wrong row. The offset is constant, doesn't depend on window position, and disappears when the window is maximized. That suggests the right-click hit-test for an attached, non-maximized Quote Board is computed relative to the window rect (including the title bar/border) rather than the client rect, so the offset equals the title bar height. To reproduce: attach the Quote Board, make sure it is not maximized, then right-click a symbol and use Roll Forward. Workaround in the meantime: keep the Quote Board maximized or detached, or carefully right-click the top edge of the row that is 2 rows above the symbol that you want to effect. |
| [2026-10-23 19:43:31] |
Thank you for the additional information. This will be resolved in the next release. It was a minor mistake, involving the screen to client translation. It should have applied to the internal Quote Board list.
