Date/Time: Fri, 13 Nov 2026 09:27:54 +0000
Account
View Count: 237
| [2026-09-28 04:12:00] |
| Alekkulatti - Posts: 2 |
Hi, My account Alekkulatti still shows "Restricted" on the Last Login line, and every service says "Not enabled on package", even after restarting Sierra Chart. I have never used Sierra Chart or held a Sierra account before. I'm running it on a Mac through CrossOver, which might be why it looks like a previous installation. Could you please review the account and lift the restriction? |
| [2026-09-28 04:27:39] |
thank you. if could get a response ASAP that would be appreciated. need for my work
| [2026-09-28 04:35:19] |
| Sierra_Chart Engineering - Posts: 25420 |
Go through the procedure to verify your email address here: https://www.sierrachart.com/UserControlPanel.php?page=EmailVerification This will allow the trial to be used. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
