Date/Time: Thu, 12 Nov 2026 18:55:18 +0000
F1 Key Cannot Be Used as a Keyboard Shortcut
View Count: 252
| [2026-09-26 20:58:07] |
| Deenius - Posts: 171 |
Hello, I want to use the F1 key to open the Positions window. However, when I assign this key to that window, pressing it also opens a web browser window displaying the “Working With Charts” page. Could you please ensure that this page does not open when the key is assigned to a command? Thank you. |
| [2026-09-26 22:33:49] |
| Sierra_Chart Engineering - Posts: 25416 |
You cannot use the F1 key for another purpose. It is reserved for help. Not sure we can do anything to prevent that. We will check though. No, there is not a way that we can prevent this. The operating system provides a help message anyway when you have a keyboard shortcut set up for F1. When it really should not. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-09-26 22:37:53
| [2026-09-26 23:34:13] |
Actually we know a solution to this. We will implement it in the next release.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-09-26 23:34:19
