Date/Time: Mon, 09 Nov 2026 14:59:24 +0000
hyperliquid data feed
View Count: 394
| [2026-09-26 15:32:51] |
| zxcvfdsaxzxzxz - Posts: 1 |
hello, years back there was talk building an own dex. constant issues with binance data-feeds. there is now a dex doing 30%+ of binance volume, while reflecting the btc ethos to the absolute maximum called hyperliquid with easy to implement institutional grade data feeds. https://x.com/doublezero/status/2103122298253492244. please, when can we expect to get blessed as crypto traders that still want to use sierra charts over other platforms. regards
Date Time Of Last Edit: 2026-09-26 15:33:34
| [2026-09-29 06:56:04] |
| Sierra_Chart Engineering - Posts: 25406 |
We did look at this briefly, and did not fully understand, what is this hyperliquid is all about. But one thing we notice with their APIs, none of them are oriented for a C++ program. This is what makes it difficult to use these types of interfaces. We can work with HTTP and websockets but beyond that, what they are offering is just not going to work. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-09-29 06:56:38
| [2026-09-29 17:09:54] |
| BeardPower - Posts: 55 |
Hyperliquid is just a centralized limit order book (CLOB) running on a custom Layer-1. Its public API consists strictly of standard HTTP POST endpoints and raw JSON WebSockets. Signing transactions is done via standard cryptography keys (EIP-712/Agent Wallets). It is fundamentally just an ultra-fast trading venue and no different from traditional electronic futures matching engines, except for its non-custodial clearing layer. Why exactly is Hyperliquid's API not oriented for C++? It's just standard HTTP POST and JSON WebSockets. There is nothing "beyond that". Please explain the actual technical bottleneck. |
