Date/Time: Wed, 11 Nov 2026 18:07:48 +0000
Services
View Count: 300
| [2026-09-25 16:53:27] |
| JP4INV - Posts: 1 |
I recently re-entered $50.00 to my order flow cover my services for order flow chart for NQ Futures and Gold. I just need to know which services I need to reactivate in order to get the data as I do not remember. Its what I previously was subscribed too but they all have expired. Grateful for your guidance. Thanks in advance.
| [2026-09-25 18:41:55] |
| John - SC Support - Posts: 48498 |
If you are just needing data for NQ and GC, then we would recommend activating the following exchanges: - CME Non-Professional Top-of-Book - COMEX Non-Professional Top-of-Book The cost for each of these is $2.00 per month, so your total would be $4.00 per month. Our recommendation is based on the fact that you previously had exchanges active that did NOT include Market Depth data. If you do want Market Depth data for those exchanges, then you should do the following instead: - CME with Market Depth for Non-Professional Trading Accounts - COMEX with Market Depth for Non-Professional Trading Accounts These cost $13.50 per month for each, so your total would be $27.00 per month. The other thing to keep in mind is that once you need 3 of the 4 exchanges that are part of the CME Group, then you are best served to activate one of the "Full CME Group..." exchange options, as this gives you all 4 exchanges for the price of 3. You can activate the exchanges for the CME Group at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-09-25 18:42:22
