Date/Time: Wed, 11 Nov 2026 04:55:20 +0000
BTC volume + delta combined by all exchanges
View Count: 238
| [2026-09-25 10:13:25] |
| poppadog - Posts: 1 |
I want BTC volume + delta combined by all exchanges. So can you please share details if any study or builtin feture available in Sierra chart to do it?
| [2026-09-25 15:29:49] |
| John - SC Support - Posts: 48490 |
Within Sierra Chart, you would need to open charts for the different symbols/exchanges you want the data for. Then use one of the following studies to sum the charts together: Sum All Charts Sum Charts From List There are other studies that can be used as well, but the two above would be the easiest for what you are trying to do. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
