Date/Time: Tue, 10 Nov 2026 16:48:41 +0000
How to switch from demo to live
View Count: 251
[2026-09-24 20:42:18]
Bogdan Gawlas - Posts: 2
Hi, I want to switch from the demo version to live trading. How do I do that, and how do I set up order placement? Best regards.
[2026-09-24 20:45:03]
John - SC Support - Posts: 48483
If you have your Sierra Chart setup to connect to your live trading account, then the only thing you need to do is to select "Trade >> Trade Simulation Mode On" to remove the checkmark from that option, which will then change you to trading live. Refer to the following:
Overview of Trading: Difference between Simulated and Non-Simulated Trading Modes
If you are not connected to your live account, then let us know what broker and/or trading service you are using and we can point you to the proper instructions.
We are not certain what you are asking in terms of "order placement", but perhaps the following will answer your questions:
Attached Orders
