Date/Time: Tue, 10 Nov 2026 04:28:23 +0000
LARGE VOLUME TRADE INDICATOR- ISSUE
View Count: 239
| [2026-09-24 16:59:54] |
| Khushbupatel - Posts: 2 |
Dear Sierra chart Team, I am facing an issue with the installation of this indicator on the chart. When I am applying for the 1st time with a BY-DEFAULT setting of 10 volume as a threshold it will show the data but once I am increasing it to 50 / 100 then I can't see any data on my chart of Gold / ES. Please advise how to use it or what is the mistake from my side which is obstructing this indicator. Thanks. |
| [2026-09-24 17:02:21] |
| John - SC Support - Posts: 48480 |
It doesn't sound like there is any problem with the indicator, especially since you get markers with a value of 10 for the threshold. We took a look at the Z contracts for ES and GC, and although there are a fair number of trades of 50 or above for ES (see attached image), there aren't any recent transactions of this size for GC. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
