Date/Time: Sun, 08 Nov 2026 13:52:59 +0000
The P&L for the currently active trade is not included in the daily P&L
View Count: 255
| [2026-09-24 09:03:59] |
| User388548 - Posts: 6 |
Hello, since the update the daily P&L is no more included in the Daily P&L. The daily P&L is updated only after the trade is closed. I use Version 2956 64-bit Revision 58332. Regards, Markus |
| [2026-09-24 11:37:15] |
| Sierra_Chart Engineering - Posts: 25402 |
Check this setting: Global Trade Settings Windows: Include Open P/L in Chart/Trade DOM P/L Display (NPL) (Global Settings >> Chart Trade Settings >> General >> Other) Nothing has changed with this functionality. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-09-24 13:27:57] |
It does not work anymore. The settings are unchanged. Include Open P/L in Chart/Trade DOM... was always enabled and still is. I set it to No then restarted and then again set it to Yes with no effect. Regards |
| [2026-09-24 13:40:06] |
We see what the problem is. We are resolving this. A new release will be out, in about 20 minutes.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-09-24 13:40:17
| [2026-09-24 14:45:19] |
New Version (Revision 58382) works :-) Thank you. |
