Date/Time: Sun, 08 Nov 2026 15:41:22 +0000
blurry candles on one side of chart when rezised.
View Count: 228
| [2026-09-23 17:47:12] |
| Louis Vs - Posts: 26 |
As you might be able to see in the attached image, around 1/3rd of the chart has candles that are blurry. when a chart is full screen there is no issue. when i tile charts, and the resize, as seen in the image, the issue occurs. it appears much more apparently on heikin ashi candles, or filled candlesticks rather than hollow. Small pixel scaling factor is at 1. I have tried changing high dpi settings for sierra chart to no avail. OpenGL is off ad turning it on is not the fix. It is purely a visual annoyance but is very persistent ad i have bee trying for days to get rid of it. It is not an issue with the smaller charts on the left.
| [2026-09-23 18:05:31] |
| John - SC Support - Posts: 48459 |
The image you provided is too dark for us to be able to tell anything from it. Can you get us an image that is not as dark and shows what you are seeing? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
