Date/Time: Sat, 07 Nov 2026 02:25:23 +0000
Help with a "Trade Order Error"
View Count: 264
[2026-09-22 18:46:02]
drn_futures - Posts: 4
I need help cancelling a an open position with attached orders. I have tried reconnecting the data connection and relaunching the desktop platform but nothing has worked. Below is the full message.
"2026-09-22 14:33:35.155 | Trade Order Error - CQG order update. Status: REJECTED. Text: Cannot route the order at this time. Internal Order ID: 114533. Service Order ID: 1982594262. Symbol: F.US.MESZ26. Account: 197377 *"
[2026-09-22 19:09:50]
John - SC Support - Posts: 48459
When you have a problem like this, you need to call your broker and have them close the position and cancel any orders.
We do not know why you would be getting that message from CQG. Perhaps CQG is having a problem at this time. But that message is from them, so only they can explain why you would be getting that message at this time.
[2026-09-22 19:54:09]
Thanks. I'll contact my broker.
[2026-09-23 01:01:02]
Sierra_Chart Engineering - Posts: 25392
Please move to Teton order routing. There is no reason at this time to be using CQG. You are spending more money and getting substandard service. Please move to Teton order routing:
Sierra Chart has a very good mobile application to use with Teton order routing:
Sierra Chart Teton Futures Order Routing: Web-Based Trading Panel (Mobile Device Access)
It is web-based but it is very good.
Simply tell AMP, that you want to use Teton order routing. You are going to have superior order routing and very high reliability. And zero cost.
