Date/Time: Sat, 07 Nov 2026 02:25:23 +0000
Feature Request: Save Chartbook on Application Close
View Count: 248
[2026-09-22 17:39:14]
User131476 - Posts: 6
Would it be possible to add an option to automatically save the active Chartbook when Sierra Chart is closed?
For example:
When enabled, Sierra Chart could automatically save the active Chartbook when the application is closed instead of displaying the save confirmation prompt.
This would be very convenient and would ensure that the latest Chartbook changes are saved without requiring the user to remember to save manually.
Periodic Auto-Save is useful as an additional safeguard, but a save-on-close option would be a convenient alternative when the main purpose is simply to ensure that the latest changes are saved before exiting.
Thank you for considering this feature request.
[2026-09-22 18:09:05]
User719512 - Posts: 529
If this is implemented, please make save-on-close and auto-save both options I can turn OFF.
Many times, I will save my chartbook, change settings to see if I like them, and purposely not save on chartbook close as a mechanism to revert to prior settings.
I can see however that such settings might be convenient for many people and this feature request has merit.
[2026-09-22 18:19:11]
John - SC Support - Posts: 48459
We have noted this as a Feature Request.
We can not say when we would get to any particular request.
And yes, we would only implement this as an option. We try not to change functionality as it currently exists.
