Date/Time: Sat, 07 Nov 2026 02:25:23 +0000
Teton: who cancels the attached Stop when a Market if Touched
View Count: 265
| [2026-09-22 16:48:38] |
| cferry - Posts: 18 |
We place a bracket on Teton Futures Order Routing from an ACSIL study where the attached Target is Market if Touched - Client (AttachedOrderTarget1Type = SCT_ORDERTYPE_MARKET_IF_TOUCHED_CLIENT_SIDE) and the attached Stop is a plain Stop. Your Teton page says server side bracket and OCO orders cannot be disabled, and in thread 84187 support said that with Teton all orders except Market if Touched and client orders are on your server. 1) While the Target is held on the client side, is the Stop still a server managed order (Pending Child-Server, then working on the server), exactly as it is with a Limit Target? 2) When the MIT Client Target triggers and Sierra Chart sends it as a Market order, is that Market order still part of the same server side OCO group, so that your server cancels the Stop when it fills? Or does Sierra Chart cancel the Stop from the client after it receives the fill? 3) In the second case, if the internet connection drops right after the Market order is sent, can the Stop stay working on the server with a flat position until Sierra Chart reconnects? Related: thread 39093 (December 2018), where the Stop was left open after a Market If Touched CLIENT target filled. |
| [2026-09-22 18:32:12] |
| Sierra_Chart Engineering - Posts: 25392 |
All of this is managed on the client side. Refer to: Order Types: Sierra Chart Management of Trailing Stop and Chase Orders Yes so long as the parent order has filled: can the Stop stay working on the server with a flat position until Sierra Chart reconnects?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-09-22 18:32:33
