Date/Time: Sun, 08 Nov 2026 14:05:01 +0000
Account Reminder
View Count: 332
| [2026-09-22 16:09:00] |
| junior - Posts: 2 |
can u tell me why the voumes colors are not highlighted on my volume profile
| [2026-09-22 16:11:54] |
| John - SC Support - Posts: 48459 |
Most likely it is due to the Volume Profile being compressed too much, so you are not able to visiualize the individual bars. To solve this, either expand the scale, or set the "Ticks per Volume Bar" to a larger value. Refer to the following: Volume By Price Study: Ticks Per Volume Bar -- Please post these kind of questions in this Support Board. The Account Support Tickets are a lower priority for us. Additionally, if you keep posting, that moves your post to the most recent posts. We do a triage to make sure we answer critical questions, but then we work from oldest to newest. So when you keep posting, you are only moving your post further away from being responded to. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-10-17 01:56:39] |
| junior - Posts: 2 |
hello its not working idk y
| [2026-10-19 14:26:04] |
Your account is expired - it ended on July 15, 2026.
