Date/Time: Fri, 06 Nov 2026 01:39:20 +0000
IRONBEAM BROCKERAGE ACCOUNT
View Count: 267
| [2026-09-21 23:05:25] |
| User166249 - Posts: 27 |
Hi, I will soon be opening a second brokerage account with Ironbeam. Could you please confirm whether Ironbeam is compatible with Sierra Chart and Teton Order Routing? What information do you need from me to add my new Ironbeam account to my current Sierra Chart setup? I currently have an account with AMP Futures. Will my AMP account continue to work normally once the Ironbeam account is added? I would like to keep both accounts active and be able to use them with Sierra Chart. Best regards, Dr. Gérard |
| [2026-09-22 14:36:03] |
| John - SC Support - Posts: 48449 |
Ironbeam supports the Teton Order Routing service, so you can set this up with them. Follow the instructions at the following link: Sierra Chart Teton Futures Order Routing: Setup Instructions In terms of how you setup your Sierra Chart, apart from the instructions linked above, you will want to install a second Sierra Chart. Since these are two different clearing firms, you can not be connected to both of them at the same time from a single Sierra Chart. So you want the two installations in order to be able to have charts open for both connections. As long as you install the second Sierra Chart on the same computer, there are no additional fees. Refer to the following: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
