Date/Time: Sat, 07 Nov 2026 11:56:56 +0000
Control Bar
View Count: 327
| [2026-09-21 13:57:56] |
| Jimmyy - Posts: 357 |
I have two charts with their own control bars. I want to have separate names for the same command in both the control bars. If i change the name of the command, they get changed at both the control bars. (even though i am using different numbered control bar for both the charts) At least for a different numbered control bar should have the abilities to set different name for commands. Date Time Of Last Edit: 2026-09-21 13:58:35
| [2026-09-21 16:43:48] |
| John - SC Support - Posts: 48459 |
This is not how Sierra Chart is setup. A control bar item is a singular item, so changing it's properties within any control bar changes those properties for all control bars.
| [2026-10-05 15:51:32] |
Is it possible to add some space between the rows of control bar ?
| [2026-10-05 22:53:00] |
| Sierra_Chart Engineering - Posts: 25397 |
We will check on this.
| [2026-10-06 13:41:36] |
We will need to add a new setting to control this.
| [2026-10-07 07:01:45] |
that would be great
