Date/Time: Sun, 08 Nov 2026 13:52:59 +0000
Chart Tab colors missing
View Count: 273
| [2026-09-21 06:18:50] |
| nicktrader - Posts: 817 |
After updating to 2954, I miss the colors of the LINK numbers on the Chart tab.
| [2026-09-21 06:54:19] |
| Sierra_Chart Engineering - Posts: 25402 |
Nothing has changed with this.
| [2026-09-21 07:09:35] |
Pls see screenshot. I changed nothing...
| [2026-09-21 07:21:17] |
We will check.
| [2026-09-24 14:06:58] |
| Jimmyy - Posts: 357 |
yes, for me as well, the chartbook tab color seems to be not working.
| [2026-09-24 14:10:09] |
This has been resolved. Update to the current version. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
