Date/Time: Thu, 05 Nov 2026 00:34:13 +0000
[Programming Help] - Can't seem to be able to build a dll.
View Count: 217
| [2026-09-20 19:20:28] |
| usgvince - Posts: 30 |
The Notepad++ file wasn't located C:SierraChart\NPP\Notepad++. I couldn't find it on the hard drive, so I downloaded a different one. Changed the Notepad++ location in build program to C:Downloads\notepad++.exe was located. Placed my Notepad++ text of the study in both ASE_Source and ASC_File and tried to build from either without luck. The most common error is the text was not found after the building. Is there something specisl with the NPP\Notepad++ compared to the one I'm using. If so, can I get a new copy. I'm unsure what else it could be and I would need further help. Thanks |
| [2026-09-21 15:57:36] |
| John - SC Support - Posts: 48431 |
Sierra Chart no longer sends the Notepad++ program with our software. If you want to use the Notepad++ software, then downloading it directly from them is fine. But Notepad++ is just a text editor. We do not understand how you are attempting to build a study. Start at step #9 at the following for the instructions on how to build: How to Build an Advanced Custom Study from Source Code: Step-By-Step Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
