Date/Time: Sun, 08 Nov 2026 21:26:18 +0000
Paste list of Symbols to spreadsheet
View Count: 1339
| [2014-11-05 23:58:06] |
| User36492 - Posts: 48 |
Is there a way to paste a long list of symbols to a spreadsheet? Also, Can a sheet be linked so that clicking on a symbol will load a chart? I'm using the new speadsheets. |
| [2014-11-06 00:45:16] |
Yes. If you have a list of symbols in text format with each one on a separate line, you can paste them to a Spreadsheet using Spreadsheet >> Paste. Chart linking is only supported with Quote Boards: Getting Quotes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
