Date/Time: Sat, 07 Nov 2026 19:01:50 +0000
I just want to confirm if my parameters are correct
View Count: 1689
[2014-11-05 23:50:22]
traderbcn - Posts: 10
Hello I am trying to accomplish the following strategy and just want to make sure my settings are correct.
I would like to have a 2 target offset with 1 stop order for both contracts with a breakeven + 1 tick strategy.
1st Target - 5 ticks
2nd Target - 10 ticks
Stop for all - 5 ticks
When the first target is hit I would like my stop to move to breakeven plus 1 tick to cover commissions for the trade.
Can you confirm if the following settings per screenshot will achieve the following?
http://puu.sh/cERQl/84924c5a52.png
imagebreakeven.png / V - Attached On 2014-11-05 23:47:27 UTC - Size: 13.38 KB - 595 views
[2014-11-07 04:15:04]
This looks correct.
You could change the breakeven trigger to be OCO Group triggered instead. We recommend that.
