Date/Time: Mon, 02 Nov 2026 23:00:11 +0000
NES (E-mini S&P 500 Nano) missing from CME symbol list
View Count: 294
| [2026-09-17 09:45:11] |
| User131476 - Posts: 6 |
The new E-mini S&P 500 Nano contract (NES) does not appear at all in: File → Find Symbol → Futures - CME I have already updated the Global Symbol Settings from the server and restarted Sierra Chart, but NES is still not listed. I can only access it by entering the symbol manually as `F.US.NESU26`. When I do that, Sierra shows: “Real-time data subscription for instrument F.US.NES is not enabled. Click for symbol information.” I am using: Data/Trade Service: CQG WebAPI Market data: Denali Exchange Data Feed Order routing: CQG WebAPI through AMP Futures (I cannot use Teton because of the higher margin requirements) CME Market Depth subscription: active Broker: AMP Futures MES real-time data works correctly. Is NES currently available through the Denali CME Market Depth subscription, and why does it not appear in the CME symbol list? |
| [2026-09-17 18:41:35] |
| Sierra_Chart Engineering - Posts: 25355 |
We have not added these symbols for CQG. We will ask AMP about this: Order routing: CQG WebAPI through AMP Futures (I cannot use Teton because of the higher margin requirements) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-09-17 19:49:50] |
Update: I no longer need this for my own setup, as I was only testing it. However, adding these symbols for CQG may still be useful for other users.
| [2026-09-17 22:02:19] |
Also with AMP, the higher margin requirement is only overnight and we did ask them about that and they did give us an answer and hopefully that will go away at some point.
