Date/Time: Sun, 01 Nov 2026 12:12:19 +0000
Not able to see right side of chart (huge margin space)
View Count: 412
[2026-09-15 19:40:13]
User558370 - Posts: 23
Ive attached screenshots because it's hard to explain. In many charts, but not all, there is a huge gap on the right side and when i scroll right, the chart just disappears and I am left with a huge BLANK margin space. I can resize the chart all I want but that huge margin space remains.
What settings should I look at to remove this huge margin space?
Please see attached pictures.
imagechart problem.jpg / V - Attached On 2026-09-15 19:39:20 UTC - Size: 212.56 KB - 55 views
imagechart problem 2.jpg / V - Attached On 2026-09-15 19:39:24 UTC - Size: 212.88 KB - 54 views
[2026-09-15 19:50:49]
That is caused by the option for "Chart >> Lock Fill Space". Refer to the following:
Chart Menu: Lock Fill Space (Chart menu)
There is also an option to create a "temporary" fill space by holding the Control button while using the scroll wheel on your pointing device. Once the last bar is scrolled back into view, then this temporary fill space is removed. Make sure you are not accidentally creating this situation as well.
[2026-09-17 04:42:31]
TraderBake - Posts: 63
Control bar command "Scroll all charts to end" is a fast solution.
