Date/Time: Fri, 30 Oct 2026 17:42:01 +0000
free trial /payment options
View Count: 257
| [2026-09-15 10:32:21] |
| User832397 - Posts: 1 |
Please can you help me get this. Free trail run again Please? free trial simulated delayed mode needed to co exist with G7FX course . I want to understand and learn. Regards IAN. |
| [2026-09-15 14:45:47] |
| John - SC Support - Posts: 48369 |
We can only give you the trial time that you have not used. In this case, this is 17 days. We have added this time to your account. Once you use up the trial time, you would need to change to a paid package. The "Base" packages are a little less expensive and are meant for continued learning and development, as you can not connect to data or trading services on those packages. Refer to the following: Description of Service Packages and Pricing: Packages When you are ready to change to a paid package, follow these instructions: Sierra Chart Purchase and License Information: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
