Date/Time: Mon, 14 Sep 2026 22:46:27 +0000
Changing to Teton
View Count: 16
| [2026-09-14 21:19:40] |
| User563703 - Posts: 13 |
I am attempting to switch my service from CGQ to Teton and I am getting an error message, when I try to verify sierra username. I am uploading a picture of the error. In the AMP Sierra Account name/username I am using "Dukerock"
| [2026-09-14 21:58:29] |
| John - SC Support - Posts: 47889 |
That error typically means that the email address you have set in Sierra Chart does not match the email address you have set with AMP. Please check the email addresses and ensure they are set exactly the same. You can find your Sierra Chart email address at the following link and change it there if you need to: https://www.sierrachart.com/UserControlPanel.php?page=ManageAccountInfo For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
