Date/Time: Fri, 30 Oct 2026 04:59:22 +0000
VWAP - Is it possible to configure it to HLC/3?
View Count: 338
| [2026-09-14 18:45:56] |
| User339024 - Posts: 18 |
Using DOM, added VBP to it and no matter what I do can Not configure VWAP to HLC/3. Would appreciate anyone advising me on how to set this simple thing on to HLC/3 ??? Thank you, Stella |
| [2026-09-14 19:26:26] |
| John - SC Support - Posts: 48369 |
There is no support for the VWAP calculation to be based on HLC/3. With the Volume by Price VWAP, the VWAP is calculated from the underlying tick-by-tick data (or whatever increment you have your data stored). The "Volume Weighted Average Price" study can be defined to use the HLC/3 data rather than the Last. This is controlled through the "Input Data" input for the study. Refer to the following: Volume Weighted Average Price (VWAP) with Standard Deviation Lines: Inputs For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-09-15 00:51:44] |
| joshtrader - Posts: 569 |
Why would you want to set it to a much less accurate calculation method than using the most granular data possible? |
| [2026-09-15 08:20:01] |
| User135243 - Posts: 328 |
I guess she saw this on TradingView, which of course is nonsense :) and has nothing to do with the real calculation of VWAP
