Date/Time: Fri, 30 Oct 2026 04:59:34 +0000
Chart Scale Desynchronization — Current Price Not Aligning With Visible Bars (NQU26_FUT_CME)
View Count: 184
[2026-09-14 18:26:34]
User500 - Posts: 1
Hi Support Team,
I am experiencing a persistent display issue on my chart for NQU26_FUT_CME
(Chart 2939, Teton CME Routing). The current price level and the most
recent bars are visually disconnected—the candle appears at the top of the
chart while the price scale shows a significantly lower value, as if the
price axis and plotted data are out of sync.
Troubleshooting steps already attempted without success:
- Confirmed "Scale Range: Automatic" is enabled
- Used Reset, Reset and Lock, and Reset Bar Size/Spacing/Scale
- Verified "Auto Scale" settings from the right-click scale menu
- Checked Symbol Settings for mismatched multipliers
Additional context:
- This occurs specifically on the NQ futures contract while connected via
Teton/Denali.
- The issue persists after switching between contract months (e.g., NQH27
to NQU26).
- The data feed status in the title bar shows "DF:93656 ST:3, 3".
Could you please help identify whether this is a symbol mapping issue, a
data feed synchronization problem, or a display bug? Let me know if there
are specific settings I should check or logs I can provide to help diagnose
the issue
Thank you for your time and support.
Best regards,
Wally
[2026-09-14 18:26:53]
John - SC Support - Posts: 48369
Please get us an image of what you are seeing by following these instructions:
