Date/Time: Fri, 30 Oct 2026 04:59:49 +0000
Rithmic Direct connection problem
View Count: 188
| [2026-09-14 16:13:25] |
| User551991 - Posts: 1 |
After following instructions from APEX and Sierra Charts on how to connect Sierra Charts with APEX. I continue to get permission denied error when attempting to connect through Rithmic Direct DTC in Sierra Chart. APEX support said I should contact you. Thank you for your help, Mike Knight |
| [2026-09-14 18:40:16] |
| John - SC Support - Posts: 48369 |
All we can do is refer you to the following: Rithmic Trading Platform Service: Permission Denied Resolution Procedure For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
