Date/Time: Thu, 29 Oct 2026 17:00:39 +0000
Extending rectangle not filling
View Count: 198
| [2026-09-14 14:35:50] |
| User213504 - Posts: 124 |
The title says it all. It's not filling with the selected color. When I turned on SC this morning the drawings were empty but colored so I rebuilt the chart and now the chart has the information but the extending rectangles are blank, just the lines are visible.
| [2026-09-14 15:52:57] |
| John - SC Support - Posts: 48366 |
Check the properties for the extending rectangle and see if the option for "No Fill" is set to "Yes". Change this to "No" if you want to have the fill coloring. Make sure that the configurations you use for the Extending Rectangle have that option set as you want it going forward. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-09-14 19:04:22] |
Thanks. There are so many new options. I have to remember to check them all. That setting is a little confusing in that you shouldn't confirm a negative. Better would be to confirm a positive as in "Fill Interior: Y/N". That option is also available on the rectangle. It may be available on others.
