Date/Time: Wed, 28 Oct 2026 13:59:58 +0000
Problem - GBPUSD, EURUSD Chart Calculator CV values are 0.00
View Count: 321
[2026-09-12 22:19:03]
ycomp - Posts: 334
XAUSUD, Futures contracts I tried all display proper CV values using Chart Calculator
but GBPUSD, EURUSD (and I presume also some other Forex symbols) produce 0.00, no matter how far the distance is in ticks or points using the calculator.
This carries through to the API although I can't remember the specific ACSIL functions/variables I was accessing. But I was getting 0 when I shouldn't there as well, that is how I first noticed it.. then i verified using the Chart Calculator tool.. then I verified with another instance of Sierra Chart using the Chart Calculator tool.
it is currently Saturday, so I don't know if that matters that it is not when the market is open.
I have this problem in 2 different instances of Sierra that I tested on my computer. i.e. they are in completely different folders
is there something I can do to fix this?
I'm using 2922 64 bit rev 57220
Date Time Of Last Edit: 2026-09-13 12:28:04
[2026-09-13 15:50:01]
Sierra_Chart Engineering - Posts: 25301
We do not see any obvious problems:
https://www.sierrachart.com/image.php?Image=1789257642508.png
First thing to do is to check the Price Display Format in the Chart Settings:
Chart Settings: Price Display Format (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
And also update to the current version of Sierra Chart. Instructions:
Date Time Of Last Edit: 2026-09-13 15:54:16
[2026-09-14 14:05:45]
ycomp - Posts: 334
ok, I got it to work.. I forgot to set the quantity high enough on the FOREX Symbols, so it rounded to 0.00
sorry about the false alarm
