Date/Time: Wed, 28 Oct 2026 14:00:41 +0000
Candlestick outline in column 1 without any text or background color
View Count: 215
| [2026-09-12 07:26:17] |
| SidN313 - Posts: 8 |
Hi team, In the number bars study, the dropdown list of numbers bars text for column 2 and 3 have the option "No Text - Show Column". This helps to have just a candlestick outline without any data within it. I wanted to have the same setup with just the candlestick outline in column 1 with column 2, column3 having delta and volume. But I am not able to set it up this way since column 1 does not have that option. So could you guide me on how I can set it up as how I have explained above with just the candlestick outline on column 1 without any text or background coloring within it Thank you |
| [2026-09-14 15:00:48] |
| John - SC Support - Posts: 48349 |
We have noted this as a Feature Request. We can not say when we would get to any particular request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
