Date/Time: Wed, 28 Oct 2026 01:41:20 +0000
[Programming Help] - Using ACSIL to trigger historical Intraday data request for a symbol
View Count: 281
[2026-09-11 22:35:23]
User150671 - Posts: 80
I have been trying to find a way to trigger an Intraday Data Request for a symbol other than the current chart.
I have tried:
sc.GetSymbolDataValue(ValueToReturn, Symbol, 1, 0);
This triggers the 'Starting real-time market data updates for: Symbol' but it does not add the historical Intraday data request for Symbol.
For my purposes I need the intraday historical data, I just don't need the chart itself.
I have confirmed that I can use sc.DataFile to achieve this, but again it needs a chart to run on - so it's not the solution I really want.
A way to programmatically access the Intraday File Update List and add/remove a symbol would be the ideal solution, but I think that's a non starter.
Is there anything I have missed in the ACSIL documentation that would do what I am looking for?
As an aside: using Toggle Dark Mode on the new support board message page clears everything written - so that was fun to find out.
[2026-09-12 03:15:43]
Sierra_Chart Engineering - Posts: 25299
No, you can only use this function:
sc.StartDownloadHistoricalData(const SCDateTime& StartingDateTime);
We will check on this.
Date Time Of Last Edit: 2026-09-12 03:16:03
