Date/Time: Mon, 26 Oct 2026 09:57:56 +0000
Volume Profile For Specific Sessions
View Count: 243
| [2026-09-10 20:49:50] |
| Selfmadejared - Posts: 10 |
Hello! I currently use a dedicated chart for my Weekly VWAP, Monthly VWAP, Quarterly VWAP, Yearly VWAP (All separate charts). These VWAPs are for the ETH & RTH session, so my session start time is 17:00 EST, and my session end time is 16:59:59 EST. I am trying to add a volume profile to these charts, but for the RTH session only. So for example, on my Weekly VWAP chart, I want to add a Volume Profile that is only pulling data from that week's RTH sessions, excluding the ETH session. I am having difficulty figuring out how to do this, any help would be greatly appreciated. Thanks in advance!
| [2026-09-10 21:09:10] |
| John - SC Support - Posts: 48317 |
You can not do what you are asking directly with the way you have your charts setup, since there is no definition between the day and evening sessions. The only way to do this is to have a separate chart that is just the RTH session times and add your Volume by Price to that chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-09-10 21:13:17] |
Okay thank you! Just wanted to make sure I wasn't missing anything.
