Date/Time: Sun, 25 Oct 2026 22:24:23 +0000
Not connecting to data
View Count: 184
[2026-09-10 18:24:33]
Ahmad Ali Amiri - Posts: 1
Hello there. I can no longer connect to Teton CME Routing (Trading) data feed and get attached error message. It says "No trade accounts assigned" I've never had this issue. What can I do to fix it.
imageSierra_Error.jpg / V - Attached On 2026-09-10 18:23:04 UTC - Size: 225.98 KB - 48 views
[2026-09-10 19:08:10]
John - SC Support - Posts: 48317
You need to check with your broker on why you are getting that message. The implication is that they have turned off your account for some reason.
