Date/Time: Mon, 26 Oct 2026 22:03:10 +0000
Server side OCO
View Count: 258
[2026-09-10 17:50:28]
User339024 - Posts: 18
OCO is a server side if Denali used, right?
Stop Loss is a server side in case power/internet is off, right?
But will the Breakeven get initiated if connection is off, or it's only for the Stop Loss to work?
Thank you
[2026-09-10 17:57:48]
John - SC Support - Posts: 48335
Denali is the Data Feed.
Are you asking in reference to Teton, our order routing service?
[2026-09-10 22:53:16]
Yes, Teton?
[2026-09-11 03:48:08]
Sierra_Chart Engineering - Posts: 25285
With Teton order routing, this is all server-side except for Move to Breakeven:
Refer to:
Order Types: Sierra Chart Management of Trailing Stop and Chase Orders
