Date/Time: Sun, 25 Oct 2026 22:24:18 +0000
Invisible Crosshair/Tool
View Count: 154
| [2026-09-10 14:45:09] |
| User356190 - Posts: 3 |
Hi, I'm having trouble seeing the crosshair; it makes the candlesticks transparent (covering them up and making them hard to see), and the same thing happens with the rectangle—when I try to expand it, I can't see the crosshair line.
| [2026-09-10 15:02:16] |
| John - SC Support - Posts: 48317 |
We are not able to reproduce exactly what you are seeing. From what we see of your account, it looks like you are running version 2915. Please update to the latest release and see if you continue to have an issue. There have been some changes with OpenGL support, so we think this may have already been resolved. Follow these instructions to update: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
