Date/Time: Mon, 26 Oct 2026 22:03:18 +0000
v2947 configured to display the window controls
View Count: 260
| [2026-09-10 12:55:38] |
| User14953 - Posts: 268 |
Can Sierra Chart v2947 be configured to display the window controls in the top right corner of a maximized chart?
| [2026-09-10 14:36:32] |
| John - SC Support - Posts: 48335 |
Yes. To do this, enter a lot of spaces in the "Global Settings >> General Settings >> GUI >> MDI Container Window Child Window Menu Text Separator" to push the items over to the right. Keep in mind you will need to be a little careful if you often change the size of your main Sierra Chart window (such as maximizing and restoring), as this could cause the menu line to wrap and you would have the controls showing on the left side one line down. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-09-11 00:31:52] |
Can a user search show the version number 1) when a maximized chart window's controls no longer displayed top right? 2) when Title bar height reduction first required the following procedure: - Graphics Settings: Window Title Bar
Date Time Of Last Edit: 2026-09-11 00:41:35
| [2026-09-11 05:07:00] |
| Sierra_Chart Engineering - Posts: 25285 |
Instead of using spaces you could use some other character like: -. You can configure, what is displayed on the title bar with these settings: Global Settings >> General Settings >> GUI >> Multiple Document Interface (MDI) and Custom Title Bar Settings >> Main Title Bar Fields to Display Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
