Date/Time: Sun, 25 Oct 2026 22:23:59 +0000
Why Is There a “Good Till Date Time” Option on the Target Tab If It Can't Be Used?
View Count: 188
| [2026-09-10 10:16:15] |
| Deenius - Posts: 163 |
Hello, Why is the “Good Till Date Time” option on the Target tab when it can't be used? According to the documentation, there should only be ‘Day’ and “GTC” options. Attached Orders: Time In Force If I select “Good Till Date Time,” it just switches me to “Day.” |
| [2026-09-10 12:10:24] |
| User135243 - Posts: 327 |
I see 7 different options (and just FYI, also Good Till Date Time works), perhaps your broker doesn't allow it
| [2026-09-10 14:28:18] |
| John - SC Support - Posts: 48317 |
In order to set the Attached Orders Time in Force to "Good Till Date Time", you first need to set the parent order to this option and enter a date and time for that parent order. Then you can set it for the Attached Orders which will use the same date and time as the parent.
