Date/Time: Sun, 25 Oct 2026 08:29:26 +0000
[User Discussion] - Position size calculator for Sierra Chart
View Count: 237
[2026-09-10 03:13:45]
dav19e - Posts: 5
I write custom studies for Sierra Chart and I have released a position size calculator. Two editions, same drawing on the chart.
https://www.sierrachart.com/image.php?Image=1789013286488.png
Standard
You set the position size, and it draws entry, stop and target anchored to the candle, with the dollar risk and the reward-to-risk on the labels.
Pro
Adds the other direction. You give it the dollar amount you are willing to risk and where the stop goes, and it works out the contract count for you. Up to three targets, each taking its own share of the position, and a warning when the setup goes over your risk budget. Pro includes Standard in the same download.
It never places, modifies or cancels an order. It reads two chart values, Tick Size and Currency Value Per Tick. No licence key, no login, nothing is sent anywhere. Windows 64-bit, Sierra Chart 2155 or later.
https://psc.davidhatin.com
Happy to answer anything, including the ACSIL side of it.
Date Time Of Last Edit: 2026-09-10 04:48:24
