Date/Time: Sun, 25 Oct 2026 08:29:06 +0000
Global settings not being applied
View Count: 204
[2026-09-09 21:29:25]
rperazzo - Posts: 3
Hello I am trying to change some of the tool settings in the global settings menu but they are not being applied. I have made sure use custom symbols setting is enabled on the global symbol settings menu. Any help for other things to try is appreciated
[2026-09-09 23:17:59]
rperazzo - Posts: 3
Uninstalling and reinstalling fixed it
[2026-09-10 08:28:16]
Sierra_Chart Engineering - Posts: 25262
Most probably Sierra Chart is not installed into the proper folder. It needs to be installed into \SierraChart. It can be put on any drive but needs to be installed into a folder other than Program Files. That is a protected folder and not the right folder to install Sierra Chart into.
[2026-09-10 09:32:14]
rperazzo - Posts: 3
OK I have a separate hard drive installed just for SC and it has no folders, so I just made one called program files. I will reinstall into a \SierraChart folder. Thank you
[2026-09-10 12:52:54]
Therefore, that may not have been the problem but perhaps it is because of the name.
That name may be recognized by the operating system as a special folder and it behaves differently.
