Date/Time: Sun, 25 Oct 2026 08:29:06 +0000
Selecting Number Bars - Chart goes blank - candles dissapear
View Count: 230
[2026-09-09 18:40:37]
HeyUgly - Posts: 287
Very very weird
Been a sierra user for 8 years, ive built 100's of chartbooks.
Today - i am building new ones - i load a candle stick chart, that's fine
i load the number bars study on it - everything disappears. no candles, no number bars just a blank chart
but i can see the price axis moving.
What am i doing wrong? ive done this hundreds of times.
Thank you in advance
[2026-09-09 18:42:20]
forgot to add - if a remove the number bars study -
the candles re-appear and chart is fine.
Why is the number bars not loading and messing up the charts this has never been an issue - running 2898
[2026-09-09 18:54:29]
here is the chart. i have zero idea what could be the issue
imageimage.png / V - Attached On 2026-09-09 18:54:11 UTC - Size: 66.44 KB - 53 views
[2026-09-09 18:57:11]
John - SC Support - Posts: 48317
Most likely it is the scaling. You need to expand the time scale so that you can view the information that makes up the Numbers Bars.
[2026-09-09 19:00:21]
no it doesnt matter if i zoom in to a tick, no boxes at all show up. see how close i am zoomed in on the chart? there's nothing
EDIT -= FIXED THANK YOU
Date Time Of Last Edit: 2026-09-09 19:00:54
imageimage.png / V - Attached On 2026-09-09 19:00:15 UTC - Size: 50.21 KB - 51 views
