Date/Time: Sat, 24 Oct 2026 19:04:43 +0000
trade
View Count: 238
| [2026-09-09 11:53:36] |
| Robert Wojczak - Posts: 178 |
When I bring up my trade positions window or trade account window it only stays up for a couple of seconds. anybody else having this problem?
| [2026-09-09 14:56:51] |
| John - SC Support - Posts: 48317 |
Both of those windows are "detached", therefore, they will show in your Windows Taskbar. When it is not showing on the screen, then look to see if it is listed in the taskbar. If it is, then select it and see if it comes back. We wonder if it is moving behind other windows for some reason. If the taskbar does not show the window, then restart your computer and only run Sierra Chart after it reboots and see if you have the same issue. In this case, we wonder if you are running out of Windows resources and therefore it can not display those windows. Restarting should resolve this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
