Date/Time: Tue, 08 Sep 2026 01:33:04 +0000
Combine Trades with Same Price and Type (Bid/Ask)
View Count: 33
| [2026-09-07 18:35:12] |
| User339024 - Posts: 6 |
Looks like "Combine Trades with Same Price and Type (Bid/Ask)" simply summarize past activity to show volume distribution at specific price points, which is basically Reporting vs. Execution, right? Q: Is it possible to adjust "Combine Trades with Same Price and Type (Bid/Ask)" in DOM Chart=>Chart Settings=>Chart Data to show Only summarized current traded activity instead of reporting past activity? Thank you, |
| [2026-09-08 01:05:34] |
This Combine is really strange as it prints sometime some weird numbers that have nothing to do with Current Traded Bids/Asks. If those numbers report past activity, than how come it keeps coming up after I totally cleared them??? Well, would anyone please make any sense of them??? Thanks |
| [2026-09-08 01:32:03] |
| Sierra_Chart Engineering - Posts: 24798 |
which is basically Reporting vs. Execution, right? Not sure we understand this.No: Q: Is it possible to adjust "Combine Trades with Same Price and Type (Bid/Ask)" in DOM
Although we are not sure we understand the second question.Chart=>Chart Settings=>Chart Data to show Only summarized current traded activity instead of reporting past activity? There is this setting but it applies to chart bars only: Chart Settings: Trades Combining Method (Chart >> Chart Settings >> Chart Data >> Chart Data menu) We do not understand post #2. We do not know exactly what you are referring to. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-09-08 01:32:33
