Date/Time: Wed, 21 Oct 2026 02:55:02 +0000
Level 2 stock data no working
View Count: 198
| [2026-09-04 17:25:31] |
| UserAR - Posts: 100 |
Please check this.. not getting data in my charts. thanks
| [2026-09-04 17:40:30] |
| John - SC Support - Posts: 48279 |
What is one symbol for which you are having a problem? We need the exact symbol as it is entered in "Chart >> Chart Settings >> Symbol >> Symbol". And are you only not seeing the Market Depth for that symbol or is the chart not updating as well? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-09-04 17:40:45] |
it appears to be working again.
